Hi I'm having a problem with saving and restoring layout. I have a pane that is unpinned. After saving the layout and then loading the layout, the unpinned pane no longer shows when clicked. Any ideas would be appreciated
Make sure no exceptions are being thrown and caught by your application. That might be hiding the problem. In either case, I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp.
