465
Data binding and Label editing problem
Hi, I am having problems getting items on UltraTree to enter edit moode.
I have set
   m_ultraTree.DataSource = new AList();
this gives me a two level tree, adding and removing items to the  Alist instance causes items to appear on the Tree.
Now I wish to be able to edit the Name (label) of each instance of AClass on the tree and have the underleying  AClass item. So I have done the following
   m_ultraTree.NodeLevelOverrides.Add(_override1);
   _override1.ShowColumns = DefaultableBoolean.False;
   _override1.UseEditor = DefaultableBoolean.True;
   _override1.LabelEdit = DefaultableBoolean.True
As a test I have added the following as a DoubleClick event handeler
    private void m_ultraTree_DoubleClick(object sender, EventArgs e)
        UltraTreeNode node = m_portsTree.SelectedNodes[0];
        node.BeginEdit();
        node.EditorResolved.Value = "change";
        node.EndEdit(false);
This method fails on node.EditorResolved.Value = "change" with the exception "Can't access the 'Value' property when not in edit mode".
Ok thinking I need to edit as cell instead I tried
    private void m_portsTree_DoubleClick(object sender, EventArgs e)
        UltraTreeNodeColumn column = node.DataColumnSetResolved.Columns["Name"];
        column.AllowCellEdit = AllowCellEdit.Full;
        bool c = node.BeginCellEdit(column);
        column.EditorResolved.Value = "fff";
        node.EndCellEdit(true);
As before I get an exception and c is false.
How can I get this code to work.
FYI there is the Alist and AClass.
    public class AList : BindingList<AClass>
    public class AClass: INotifyPropertyChanged
        public event PropertyChangedEventHandler PropertyChanged;
        private string m_name;
        private readonly BindingList<string> m_bList;
        public AClass (string name)
            m_name = name;
            m_bList = new BindingList<string> ();
        public string Name
            get { return m_name; }
            set
                m_name = value;
                if (PropertyChanged != null)
                    PropertyChanged(this, new PropertyChangedEventArgs("Name"));
        public BindingList<string> Blist
            get { return m_bList; }
