260
Building a dynamic grid on the fly?
Could the following be accomplished with the UltraGrid control and how (example, documentation, etc...)Basically I'll have a form with a single grid, the user will select items from a combo box which then populates the UltraGrid, and each item could have a view with a different column layout.1. Populate an UltraGrid with a given view, and have the grid layout reflect the views columns. If user selects a different view, have the grid reflect its column layout, both views have different number of columns, in a sense the grid would have to be dynamic in its layout based on whatever view is used as it's data source.2. Hide columns in a grid, is there a way to select on a column at runtime in the grid and hide it? Any information is greatly appreciated. Best Regards, Nick
