3555
RefreshRow.ReloadData Issue
Ok, the problem is I am trying to call the following method,
I am working with ADo disconnected data. So to prevent to grid from
redrawing back to its original state I merge the datatable that is binded to
the grid with the new updated data table, and then I call the above method.
This has worked before, but for some reason it is not working right away.
Now I did step through my code, and the merge works fine, as I printed both
the current binded table and the new table and the final merge table.
However, it seems the actual RefreshRow.ReloadData doesn't happen until I do
an additional aftercellupdate event. I have spent hours trying to figure
this out.
Code is below and I made a comment in bold red where I think the problem is.
~Patrick
Sent: Friday, September 26, 2008 1:57 PM
To: Ryan, Patrick
Subject:
private DataTable PricingListLoader2()
DataTable dt = new DataTable();
ReviewerPricingDrugSelectByVersionID pricingSelect2 = new
ReviewerPricingDrugSelectByVersionID();
try
pricingSelect2.Invoke();
//Add calculated columns to the dataset
dt = pricingSelect2.ResultSet.Tables[0];
dt.PrimaryKey = new DataColumn[ { dt.Columns[0] };
dt.Columns.Add(new DataColumn("PricePerUnit",
Type.GetType("System.Decimal"), "[ExManSales] / [UnitSales]"));
dt.Columns.Add(new DataColumn("PricePerDoseUnit",
Type.GetType("System.Decimal"), "[PricePerUnit]/
[DoseUnitsPerReportedPrice]"));
dt.Columns.Add(new DataColumn("PricePerAdminDay",
Type.GetType("System.Decimal")));
dt.Columns["PricePerAdminDay"].ReadOnly = false;
dt.Columns.Add(new DataColumn("PricePerTreatedDays",
dt.Columns["PricePerTreatedDays"].ReadOnly = false;
for (int i = 0; i
decimal doseUnitsPerAdminDay =
Convert.ToDecimal(dt.Rows[i]["DoseUnitsPerAdminDay"].ToString());
decimal MgPerAdminDay =
Convert.ToDecimal(dt.Rows[i]["MgPerAdminDay"].ToString());
int MgPerDoseUnit =
int.Parse(dt.Rows[i]["MgPerDoseUnit"].ToString());
decimal compareZero = 0.0M;
decimal pricePerDoseUnits =
Convert.ToDecimal(dt.Rows[i]["PricePerDoseUnit"].ToString());
if (MgPerDoseUnit > 0 && MgPerAdminDay > compareZero)
dt.Rows[i]["PricePerAdminDay"] = pricePerDoseUnits /
(MgPerAdminDay / MgPerDoseUnit);
else
if (doseUnitsPerAdminDay > compareZero)
pricePerDoseUnits / doseUnitsPerAdminDay;
else
dt.Rows[i]["PricePerAdminDay"] = compareZero;
//Fill PricePerTreatedDays column
for (int j = 0; j
decimal dayDurationOfDose =
Convert.ToDecimal(dt.Rows[j]["DaysDurationOfDose"].ToString());
if (dayDurationOfDose > 0.0M)
decimal priceAdminDay =
Convert.ToDecimal(dt.Rows[j]["PricePerAdminDay"].ToString());
dt.Rows[j]["PricePerTreatedDays"] = priceAdminDay /
dayDurationOfDose;
else
dt.Rows[j]["PricePerTreatedDays"] = 0.0M;
catch (Exception ex)
EventLogger el = new EventLogger();
bool isLogged;
dt = null;
isLogged = el.WriteToEventLog(ex.Message,
"MarketForecasterApp", EventLogEntryType.Error, "MarketForecaterApp");
if (isLogged == true)
MessageBox.Show("Event logged.");
return dt;
private void grdPricingList_AfterCellUpdate(object sender, CellEventArgs e)
EditorPricingDrugUpdate pricingDrugUpdate = new
EditorPricingDrugUpdate();
PricingDrug pricingDrug = new PricingDrug();
string myString =
grdPricingList.ActiveRow.Cells["PricingDrugID"].Value.ToString();
pricingDrug.PricingDrugID =
int.Parse(grdPricingList.ActiveRow.Cells["PricingDrugID"].Value.ToString());
pricingDrug.Weights =
Convert.ToDecimal(grdPricingList.ActiveRow.Cells["Weights"].Value.ToString());
pricingDrug.DoseUnitsPerReportedPrice =
int.Parse(grdPricingList.ActiveRow.Cells["DoseUnitsPerReportedPrice"].Value.ToString());
pricingDrug.DoseUnitsPerAdminDay =
Convert.ToDecimal(grdPricingList.ActiveRow.Cells["DoseUnitsPerAdminDay"].Value.ToString());
pricingDrug.MgPerDoseUnit =
int.Parse(grdPricingList.ActiveRow.Cells["MgPerDoseUnit"].Value.ToString());
pricingDrug.MgPerAdminDay =
Convert.ToDecimal(grdPricingList.ActiveRow.Cells["MgPerAdminDay"].Value.ToString());
pricingDrug.DaysDurationOfDose =
Convert.ToDecimal(grdPricingList.ActiveRow.Cells["DaysDurationOfDose"].Value.ToString());
pricingDrugUpdate.PricingDrug = pricingDrug;
try
pricingDrugUpdate.Invoke();
tblMerge = PricingListLoader2();
tblMerge.PrimaryKey = new DataColumn[ {
tblMerge.Columns["PricingDrugID"] };
// Merge new data into the modified data
tblPricingDrug.Merge(tblMerge, false);
this.grdPricingList.Rows.Refresh(Infragistics.Win.UltraWinGrid.RefreshRow.ReloadData);
THIS DOESN"T WORK UNTIL I DO ANOTHER AFTERCELLUPDATE
EVENT, IT SEEMS THE RELOAD IS ALWAYS ONE STEP BEHIND)
//grdPricingList.Rows.Refresh(RefreshRow.ReloadData);
//grdPricingList.Refresh();
MessageBox.Show("Did Not Update To Database: " +
ex.Message);
