1320
UltraChart GanttChart Borders
Hi to All.  There is a property of the UltraChart control that I seem unable to locate and/or change.  It is shown in the diagram below as the region between the X2 axis line and the top of the control.  In this example the X2 Axis is visible (i.e. UltraChart1.Axis.X2.Visible = True) but its extent is zero (i.e. UltraChart1.Axis.X2.Extent = 0).  Setting UltraChart1.Axis.X2.Visible = False or changing the Margin and Padding properties of the control do not fix this problem either.
