229
Translate UI
Hi all,
I am a newbie here, doing my first steps into Infragistics.
One of the things I cannot find is how I could translate the user-interface (filtering/ sorting etc. ) of UltraGrid.
What would be the best scenario to do this?
tia,
Erik Visser
  • 125
    Verified Answer
     Hi, here is my solution to do that:
    Strings for controls are located in resources. Help link
     ms-help://INFRAGISTICS_NETEN82CLR2_HELP/NetAdvantage_NETEN82CLR2/Win_NETEN82CLR2/WinElements/Win_Assembly_Resource_Strings.html
    contains description of string you can translate.
    I have a txt file which contains
    MoreWindowsDlgClose Закрыть
    MoreWindowsDlgCloseWindows Закрыть окно(а)
    MdiCommandCloseWindows Закрыть все окна
    where first word is Key of a string that need to be translated
    " " splits translation(in this case - russian)
    This file is located in resources.
    then in code i have an util class which contains few methods
    public static void LocalizeControls()
                    Infragistics.Shared.ResourceCustomizer cust = Infragistics.Win.UltraWinGrid.Resources.Customizer;
                    StringReader r = new StringReader(Properties.Resources.translate);//this is txt file
                    while (true)
                        string line = r.ReadLine();
                        if (line != null)
                            KeyValuePair<string, string> val = GetKeyValue(line);
                            cust.SetCustomizedString(val.Key, val.Value);
                        else
                            break;
                    cust = Infragistics.Win.UltraWinTabbedMdi.Resources.Customizer;
                    r = new StringReader(Properties.Resources.tabbedmdi);
                    while (true)
                        if (line != null)
                        else
                            break;
                    cust = Infragistics.Win.UltraWinToolbars.Resources.Customizer;
                    r = new StringReader(Properties.Resources.toolbar);
                    while (true)
                        if (line != null)
                        else
                            break;
                    cust = Infragistics.Win.Misc.Resources.Customizer;
                    r = new StringReader(Properties.Resources.misc);
                    while (true)
                        if (line != null)
                        else
                            break;
            public static KeyValuePair<string, string> GetKeyValue(string line)
                string key;
                string value;
                     key = line.Substring(0, line.IndexOf(" "));
                    value = line.Substring(line.IndexOf(" ") + 1, line.Length - line.IndexOf(" ")-1);
                return new KeyValuePair<string, string>(key, value);
    when a program starts you call the LocalizeControls() method
