625
Adding items dynamically in BeforeToolDropDown...
I'm having some trouble with this...
I'm trying to control what items will appear in the menu when a user right clicks over my grid.  This code is used in other places in the application and seems to work; but in this particular instance only the tools that are of type 'PopupMenuTool' appear.  I have some StateButtonTools and some ButtonTools are coded to appear - but they just don't show up.
Here is the code I use to show a PopupMenuTool - this works great....
mnuPopUp = CType(mnuRCGridMenu.Tools("Test1"), Infragistics.Win.UltraWinToolbars.PopupMenuTool)
mnuPopUp.SharedProps.Visible = True
But when I try the same thing with a StateButtonTool - it doesn't appear for the user...
sbItem = CType(mnuRCGridMenu.Tools("Test2"), Infragistics.Win.UltraWinToolbars.StateButtonTool)
sbItem.SharedProps.Visible = True
Using a debugger, I've set a breakpoint after the two lines immediately above this text and I find that 'sbItem.VisibleResolved' is 'False'.  But it's SharedProps.Visible is true.  I don't know what else could be hiding it.
sbItem.EnabledResolved is true.
sbItem.OwningMenu.VisibleResolved is true.
Does anyone have any thoughts or suggestions on why these item's might not be showing?
