1175
Can I make a cell with a value list read only?
I have a column with a value list, when the user clicks the cell it goes into edit mode so I added this code
 e.Layout.Bands[0].Columns["Column Format"].CellClickAction = CellClickAction.CellSelect;
after adding that it only goes into edit mode after the user selects an item in the value list, but I don't want the user to be able to edit the text at any point.
here is the code I use for the value list
 ValueList vl;
if (!e.Layout.ValueLists.Exists("Formats"))
vl = e.Layout.ValueLists.Add("Formats");
vl.ValueListItems.Add("#"); vl.ValueListItems.Add("#.0");
vl.ValueListItems.Add("#.00");
vl.ValueListItems.Add("#.000");
vl.ValueListItems.Add("#.0000");
e.Layout.Bands[0].Columns["Column Format"].ValueList = e.Layout.ValueLists["Formats"];
Thank you, Jamie
