I am trying to cycle through the grids row collection; i keep getting an exception thrown at me about "unable to cast ultraGridRow to ultraGridGroupByRow" "weird". Any way. Any suggestions would be appreciated. Here is the code I am using for now.
try
// breaks during iteration
Unable to cast object of type 'Infragistics.Win.UltraWinGrid.UltraGridRow' to type 'Infragistics.Win.UltraWinGrid.UltraGridGroupByRow'.
catch { }
I just found the exception further up the stack. Sorry for the waste of time, code works fine for me as well.
This code worked for me, so I'm not sure what's different in your application. Is this a flat grid (granted with grouped rows), or is there a hierarchy? You could naturally just use an UltraGridRow and check its type before proceeding, but I'd think that this should work as-is.
-Matt
