450
Floating Toolbar Position and Size
Hi
Please advise as to how I would set a floating toolbar's position and size?
 The utMain.Toolbars[0].FloatingLocation.X says  Gets / sets but does not allow setting a value;
How would the FloatingSize be manipulatedf as well?
Thank you
  • 44743
    The compiler will not allow you to directly manipulate value types returned from a property. This is because getting the property makes a copy of the value type on the stack. Then if you were to set a property on the value type, it would set the property on the copy. As soon as the statement was over, the copy of the value type would be lost. Instead, you have to set the FloatingLocation property directly:
    utMain.Toolbars[0].FloatingLocation = new Point(newXValue, utMain.Toolbars[0].FloatingLocation.Y);
    The same applies to the FloatingSize because it is also a value type.
