I've got a line chart where time is plotted on the X axis, and I can't figure out how to get the time value and format it in my IRenderLabel implementation for the tooltip. I don't see anything in the docs that appears like it would work. I tried DATA_COLUMN, but it seems to just be a column index and not the X coordinate value.
Thanks!
try TIME_VALUE.
here's a little code trick to view all the label keys/values in the tooltip context...
private void Form1_Load(object sender, EventArgs e) { Hashtable labelHash = new Hashtable(); labelHash.Add("MY_LABEL", this); this.ultraChart1.LabelHash = labelHash; this.ultraChart1.Tooltips.FormatString = "<MY_LABEL>"; } #region IRenderLabel Members string IRenderLabel.ToString(Hashtable context) { foreach (object o in context.Keys) { Console.WriteLine(o.ToString() + " // " + context[o].ToString()); } return "hi"; } #endregion
