I need to programatically reorder groups. I saw this post (http://forums.infragistics.com/forums/t/7869.aspx) and it works except it seems to lose any controls within the group's controlContainer. I've got multiple groups, some of which contain a treeview. New groups may have been added by the end-user as well, so at run-time I don't know exactly which group has what.
Is there any way to reorder the groups without losing what they contain?
Using v 8.1.
JL
No, I don't. I know it was not in the original release (8.1.20081.1000). You can find out on our support site or by contacting Developer Support.
Thanks Brian.
Do you know what version the new overload is in? I'm seeing one Remove method which takes Group as an argument. We have v 8.1.20081.1000.
The UltraExplorerBarGroupsCollection.Remove method was recently (March 2008) overloaded so that the caller could specify whether to dispose of the associated control container...for obvious reasons, we dispose of it by default, but if you know you are going to be inserting the group right after it is removed, you could use this overload, and then use the Insert method to reorder it.
