Is there a more efficient way of implementing a singleton pattern on mdi child forms? Here is what I have...
I created a custom form class that inherits from a Form...
Imports System.Windows.FormsImports System.ComponentModelPublic Class CustomMDIChildForm Inherits Form Private _singletonOnly As Boolean = False <Browsable(True)> _Public Property SingletonOnly() As Boolean Get Return _singletonOnly End Get Set(ByVal value As Boolean) _singletonOnly = value End Set End Property End Class
I inherit this when creating a form I know will be an MDI child...
Public Class frmSomeMDIChildForm Inherits CustomMDIChildForm ... .. . End Class
Then in my parent form, I have this method....
Public Sub LoadMDIForm(ByRef theForm As CustomMDIChildForm) Me.Cursor = Cursors.WaitCursor Dim sStatus = "Loading " & theForm.Text & " functionality..." ToolStripStatusMessages.Text = sStatus Me.Refresh() Dim bFoundSingleton As Boolean = False Dim sForm As CustomMDIChildForm = Nothing ' If the form is only supposed to be a singleton. If theForm.SingletonOnly Then ' Check first if one is already loaded. For Each sForm In Me.MdiChildren ' If found, make it selected. If sForm.Name = theForm.Name Then bFoundSingleton = True Exit For End If Next If bFoundSingleton Then sForm.Activate() theForm = sForm Else With theForm .MdiParent = Me .Dock = DockStyle.Fill .Show() End With End If Else ' Not a singleton, so load up a new instance of the form. With theForm .MdiParent = Me .Dock = DockStyle.Fill .Show() End With End If Me.Cursor = Cursors.Default ToolStripStatusMessages.Text = String.Empty End Sub
End Sub
This works great, but not sure if this is a good approach.
BTW: I'm using ByRef because I have other funky stuff I am doing for specific forms, like selecting a specific datagrid row on a singleton form.
Any feedback is appreciated,
Paul
