I am using UltraToolBar in my application, the style sheet i've used is Office2007Blue. I know that Office2007 look-and-feel works best with Calibri font, but its not free so i've provided Powerpoint Viewer with my application just for installing Calibri fonts. Now in my application wherever im using Calibri font explicitly its showing fine, but the main problem is on ribbon, as im using the default settings. The fonts are still SansSerif. On my PC it is showing Calibri at runtime but on clients PC its showing Sanserif. As i've realized its working fine on my PC coz i've got Office2007 installed and its getting default settings from Office but on clients PC no Office2007 is installed. Could u suggest a workaround plz coz the beauty of Ribbon is undermined without Calibri fonts.
Thnks in advance
--Ayub
I'm not sure what font size is used on the Office Ribbon, but it's possible the crisp look occurs with a specific font size. You might just have to use trial and error to try and get it right. If it still doesn't look good, it might be a bug. If so, you can submit it to the support group: http://ko.infragistics.com/gethelp.
Hi Mike,
I know that Calibri font can be set explicitly but it doesnt give the same crisp appearance. If i apply different stylesheets, the font appearance changes on the ribbon. By the way whats the standard size of Calibri font being used on Office ribbon.
Thnks
If the font is installed on the client's PC, you should be able to explicitly set the toolbars manager's Appearance.FontData.Name to Calibri.
