80
ISSUE: UltraListView item removal causes itemactivate event to fire
To,
Infragistics Support,
I have following simple code.
private void Form1_Load(object sender, EventArgs e)
AddItems(10,
"abc", "pqr");
AddItems(20, "xyz", "wxy");
AddItems(30, "mns", "jpg");
class Order
public int Id = 10;
private void AddItems(int id, string s1, string s2)
Order o1 = new Order();
o1.Id = id;
UltraListViewItem item = new UltraListViewItem(s1, new string[
s2
item.Tag = o1;
ultraListView1.Items.Add(item);
private void button1_Click(object sender, EventArgs e)
UltraListViewItem ulv = ultraListView1.SelectedItems[0];
ultraListView1.SelectedItems.Remove(ulv);
ultraListView1.Items.Remove(ulv);
private void ultraListView1_ItemActivated(object sender, ItemActivatedEventArgs e)
UltraListViewItem item = e.Item;object o = item.Tag;
Issue:
when the line ultraListView1.Items.Remove(ulv); is being executed, usually it shouldn't fire any event.
but in this case
being called from UltraListView internal routine/event mechanism.
we can always argue that
if ( item == null) should be there in ultraListView1_ItemActivated(...) this method. but
my question is why it is calling this event when the item is being removed ?
Please clarify.
Paresh
  • 69832
    The event probably should have been named 'ActiveItemChanged'; it is being called because the value of the ActiveItem property has changed. Note that this is a peer-to-peer forum, and not intended for logging bug reports. You should report this issue via the web support form so that you are notified when a fix becomes available.
