575
TabNavigation.NextControlOnLast [Editable?] Cell?
Can I request a feature change so that when a grid's TabNavigation property is set to NextControlOnLastCell, that the last cell part of that means the last editable cell? Either that or a new enum member like NextControlOnLastEditableCell? We have cases where the last cell of the grid is not editable and cannot be tabbed into (by user request). When we are on the last cell that allows edits, we'd like the tab key to send user to next control. It does not and we are currently forced to workaround in sloppy fashion...
Inherited UltraGrid Class w/likely imperfect methods for determining if on the last editable cell in grid: .csharpcode, .csharpcode pre { font-size: small; color: black; font-family: Consolas, "Courier New", Courier, Monospace; background-color: #ffffff; /*white-space: pre;*/ } .csharpcode pre { margin: 0em; } .csharpcode .rem { color: #008000; } .csharpcode .kwrd { color: #0000ff; } .csharpcode .str { color: #006080; } .csharpcode .op { color: #0000c0; } .csharpcode .preproc { color: #cc6633; } .csharpcode .asp { background-color: #ffff00; } .csharpcode .html { color: #800000; } .csharpcode .attr { color: #ff0000; } .csharpcode .alt { background-color: #f4f4f4; width: 100%; margin: 0em; } .csharpcode .lnum { color: #606060; }
/// <summary>
        /// Returns true if the current active cell is the last editable cell in the grid
        /// </summary>
        /// <returns></returns>
        public bool IsLastEditableCellInGrid()
            return IsLastEditableCellInGrid(this.ActiveCell);
        /// <summary>
        /// Determines whether specified <paramref name="cell"/> is the last editable cell in the grid
        /// </summary>
        /// <param name="cell">The cell.</param>
        /// <returns>
        ///     <c>true</c> if [is last editable cell in grid] [the specified cell]; otherwise, <c>false</c>.
        /// </returns>
        public bool IsLastEditableCellInGrid(UltraGridCell cell)
            if (null != cell)
                UltraGridRow row = this.ActiveRow;
                int cellStartIndex = cell.Column.Index + 1;
                while (null != row)
                    for (int i = cellStartIndex; i < cell.Column.Band.Columns.Count; i++)
                        UltraGridCell tempCell = row.Cells[i];
                        if (!tempCell.Hidden && !tempCell.Column.Hidden && IsCellEditable(tempCell))
                            return false;
                    row = GetNextRow(row);
                    cellStartIndex = 0;
                return true;
            return false;
        /// <summary>
        /// Determines whether specified cell is editable
        /// </summary>
        /// <returns>
        ///     <c>true</c> if [is cell editable] [the specified cell]; otherwise, <c>false</c>.
        /// </returns>
        public bool IsCellEditable(UltraGridCell cell)
            if (!this.Enabled || this.DisplayLayout.Override.AllowUpdate == DefaultableBoolean.False
                || this.ReadOnly || cell.Activation != Activation.AllowEdit
                || cell.Column.CellActivation != Activation.AllowEdit)
                return false;
            else
                return true;
        /// <summary>
        /// Gets the next row in grid based on specified <paramref name="initialRow"/>
        /// </summary>
        /// <param name="initialRow">The initial row.</param>
        public UltraGridRow GetNextRow(UltraGridRow initialRow)
            //Calling various PerformAction enumerations on the grid itself would result in more straightforward code,
            //but any of the PerformAction options that change the ActiveRow for the grid also cause the entire row to
            //flash highlighted as it changes to be the selected row. Since we're setting the new cell into Edit mode,
            //the highlight ends up in the cell by the time we are done, not the entire row, so the user sees the
            //entire row flash highlighted for a second, and it's quite jarring and unattractive (and setting BeginUpdate
            //and EndUpdate to suppress the flash does indeed fix the flash, but it introduces an unacceptable delay when
            //moving from row to row). So this code to manually find the next row might be more complex than
            //some of the other ways of doing it, but the resulting UI is much nicer.
            UltraGridRow newRow = null;
            UltraGridRow checkRow = initialRow;
            if (checkRow.HasChild() == true)
                newRow = checkRow.GetChild(ChildRow.First);
            else if (checkRow.HasNextSibling() == true)
                newRow = checkRow.GetSibling(SiblingRow.Next);
            else if (checkRow.ParentRow != null)
                do
                        checkRow = checkRow.ParentRow;
                    else
                        break;
                while (checkRow.HasNextSibling() == false);
            if ((newRow != null) && (newRow != initialRow) && (IsRowAccessible(newRow) == false))
                newRow = GetNextRow(newRow);
            if ((newRow != null) && (newRow != initialRow) && (IsRowAccessible(newRow) == true))
                return newRow;
            else
                return null;
        /// <summary>
        /// Determines whether specified <paramref name="row"/> is accessible
        /// (i.e. ancestors expanded, not hidden, not filtered out etc.)
        /// </summary>
        /// <param name="row">The row.</param>
        /// <returns>
        ///     <c>true</c> if [is row accessible] [the specified row]; otherwise, <c>false</c>.
        /// </returns>
        public bool IsRowAccessible(UltraGridRow row)
            if ((row.AllAncestorsExpanded == false) || (row.HiddenResolved == true) || (row.IsFilteredOut == true))
                return false;
            else
                return true;
In the form there is currently a quick and dirty hack:
protected override bool ProcessCmdKey(ref Message msg, Keys keyData)
bool baseResult = base.ProcessCmdKey(ref msg, keyData);
if (keyData == Keys.Tab)
//HACK alert
// yuck, w/tabnavigation of nextcontrolonlastcell infragistics won't tab to next
// control unless we are physically on the last cell, not on last editable cell
if (ControlHelper.GetActiveControl(this) == uxVariablesUltraGrid)
if (uxVariablesUltraGrid.IsLastEditableCellInGrid())
if (uxDistributionUltraGrid.Visible && uxDistributionUltraGrid.Enabled)
//currently toolstrip doesn't allow tabstop but this will cause
//grid to focus correctly so leave for now
//uxDistributionUltraGrid.Focus();
toolStrip1.Focus();
return baseResult;
