Is there a way to display the RibbonTabs right-justified on the ribbon?and the RibbonGroups within a RibbonTab?
How can I try this alternative solution of moving RibbonUIElements around?
This is currently not supported by the toolbars manager. You can submit a feature request for this: http://devcenter.infragistics.com/Protected/RequestFeature.aspx. Alternatively, you can try to use a creation filter to move the RibbonGroupUIElements around after their parent has positioned its child elements, but it may be difficult.
