1960
Cardview with UseFixedHeaders kind of behavior
I have a grid with CardView = true, and all the cards are displayed horizontally (I set CardSettings.MaxCardAreaRows = 1).  The datasource has a lot of columns so the grid displays the vertical scrollbar all the time. Also I'm using the UltraGridRow.CardCaption property to identify each card.
The problem is when the user scrolls to the bottom the CardCaptions are not visible anymore.
I understand the UseFixedHeaders property forces the grid to display the column header even though the user scrolls vertically to the bottom. Is there a way to obtain an equivalent behavior using the cardview mode?
