I have set the Band RowSizing property to Fixed. The cursor still changes to a splitter when over cell edges. I don't wan this to happen. Any help is appreciated.
-Ken
Hi Ken,
You say "cell edges". Are you talking about cells here or rows? RowSizing only affects the height of the row. If you are seeing the sizing cursor on the right or left edge of a cell, then you would need to turn off AllowColSizing.
Also, make sure you are not setting RowSizingArea and/or ColSizingArea on the override.
