The wingrid I want to export to Excel has a complex head which was designed by using wingrid's "groups and levels" and "Row Layout" column arrangement. But when I using the ExcelExport, the generated Excel document only had the heads "Name Sex Age Email Telephone", and the heads above this " Personal Info Contact Info" were not exported, how to do so? Thank you!
Personal Info Contact InfoName Sex Age Email TelephoneItem Item Item Item ItemItem Item Item Item ItemItem Item Item Item Item
The Excel Exporter will support RowLayouts when exporting, but it does not support Groups and Levels. I didn't think it was possible to use both together, but if you are using Groups and Levels to create your headers, then this will not be exported. You will probably have to use the RowLayout to create simulated group headers by using dummy columns and setting LabelPosition to LabelOnly.
