1375
StatusBar panel AutoStatusText and UltraTree Node
I've got a form that contains an UltraTree where I build nodes on the fly. Also on the form is an UltraStatusBar with one panel set to AutoStatusText.
Is there a way to set the StatusBar text so that it displays when the mouse hovers one of the nodes? I apparently can't pass the Node into the SetStatusBarText method because it's the incorrect type.
I tried adding an UltraFormattedLinkLabel as the Nodes label. I was able to call SetStatusBarText and pass in the LinkLabel and text, but the text doesn't display when over the node.
JL
