730
ToolTip's header text is blurred when i applied Infragistics.Win.DrawUtility.UseGDIPlusTextRendering = false
Hi Mike,
I've been disturbed with the font renderig in ultratexteditor  and ultraLabels. But on the forum i've seen a solution i.e. changing the textrendering mode of all the controls by using Infragistics.Win.DrawUtility.UseGDIPlusTextRendering = false, it worked fine for most of the controls. But there is a problem that header text of all the tooltips is giving a bloated effect. Check the attached picture, i've circled the header text.
  • 469350
    Do you happen to know what font you are using for the tooltip header? My guess is that it's Segoe UI or some other anti-aliased font. If that's the case, then this is a known issue and will be fixed in the next v8.2 hot fix.
