470
Next visible row?
Hallo,
my grid display rows as following:
  • some rows are filtered out
  • the rows are sorted
  • the rows are grouped
The grid is bound to a BindingSource.
How can I set the active row to the next visible row when a new row is filtered out or someone remove a record from the BindingSource?
I tried:
UltraGridRow row = grid.ActiveRow; // this is currently the FilteredOutRow
grid.ActiveRow = row.GetRowAtVisibleIndexOffset(row, 0);
but it doesn't work well.
The next problem is, when I delete a record direct from the datasource. The active row is automaticly reset.
I hope someone have an idee.
Michael
  • 469350
    Hi Michael,
    What doesn't work well about it? What's the problem?
    My guess is that the CurrencyManager is doing this.  In which case, there's really nothing the grid can do about it. You might want to turn off SynchWithCurrencyManager on the grid. This will make it so the grid does not synchronize it's active row with the current position of the BindingManager.
