715
Dynamic Styling Sample Program
I added a Setup Wizard project to the sample program.  I installed the Dynamic Styling program  and then tested it.  No files showed up in the combobox that list the available *.isl files.  I tried adding the StylesLibraries folder and its ISL files to theApplication folder but that did not help.  Please advise how to get the Setup wizard to install the Dynamic Styling program to show all ISL resources.
Rich
  • 469350
    Hi Rich,
    My guess is that the sample uses a registry key to find the location of the files. So you would need to install that registry key. You should check the code and see where it's getting the isl file location from.
