Hi:
I designed a pie chart using your software, the problem is how can I control the color of every pie, since I need to write the legend for different pie.
I saw the following function can be called (posted on your forum):
private void UltraChart_DrawItem(object sender, DrawItemEventArgs e)
PrimitiveShape currentShape = (PrimitiveShape)e.Primitive;
if (currentShape != null && currentShape.Data.ContainsKey(typeof(DataPoint)))
DataPoint dP = currentShape.Data[typeof(DataPoint)] as DataPoint;
int indexOfDataPoint = this.ultraChart1.Series[0].DataPoints.IndexOf(dP);
currentShape.BrushElement = this._BrushElements[indexOfDataPoint % this._BrushElements.Length];
but it's not working in the first line: e.Primitive.
which part I am missing, need to add more reference? I do not install Infragistics.Silverlight on my computer.
I am working under Winform infragaistics2.0 or 3.5.
thanks ...
/Cathy
