40
Binding to multiple business objects
Is there a way to bind to multiple business objects so that columns in my grid are pulling from different sources?
For example if I have an Order class and a Customer class, and I want to display the customer names along with the orders, can I do that using the two different business objects?  I also want these to appear in the same band.
 Thanks for the help!
  • 375
    maybe this will help. Add a property Customer to the Order object. This property has to be the type of the customer object. Add the related cutomer object to the property of the order object. Extend the customer object and add the following code:
    public override string ToString()
    return this.Name; // change this to the property you want
    If you add the order list as datasource to the grid a column will be added that will be showing the returned string out of the ToString method.
    Hope this will help.
    Kind regards,
    Ralf
