The problem is that while the UltraTabPageControl has focus or a control inside that container has focus if Ihold ctrl and press several different keys, the UItraTabControl switches between the tabs. I've tried capturing the keystrokes inside the TabPageControls's PreviewKeyDown but I can't get that event to fire. And the TabPageControl does not have any keydown,keypress etc. events.
I've also tried capturing inside the tab controls keydown etc. but those keystrokes are ONLY captures while the tab itself has focus and not the tabpage.
Known key combinations I have found are:
ctrl + 9, ctrl + '+', ctrl + F12, ctrl + /, ctrl + y, ctrl + o, ctrl + m.
There are more but these are enough for an example.
Was this intentional? Was this a bug?
Does anyone know of a way to capture keystrokes inside the UltraTabPage control and stop this from happening?
Thanks!
Version 6.3 is no longer supported, and it is possible the bug has been fixed in newer releases. Try upgrading to a newer release to see if it fixes your issue.
I am using reference Infragistics2.Win.UltraWinTabcontrol.v6.3. And as long as the page control has focus and you press ctrl - + for example It will change tabs.
I was not able to reproduce the behavior, but it sounds like a bug. I would recommend submitting a sample which reproduces the issue to the support group: http://ko.infragistics.com/gethelp.
