When using our application on Vista machines, the windows border isn't correctly drawn (no minimize, maximize, close buttons)
Furthermore, on some button tools, the caption isn't fully visible?!
Everything works fine om XP machines...
We are using Infragistics v7.2
Screenshot attached
Without knowing the proper steps to reproduce the issue, it is hard to say what the problem is. I would recommend contacting the support group to see if they can help you in narrowing down the steps require to reproduce this: http://ko.infragistics.com/gethelp.
I still have this problem even now - using 8.3.20083.2039. I have a large application which exhibits the problem but cannot repeat this in a smaller demo application. I have no application styling so am at a loss of how to fix this?
It seems like you're setting the back color of the UIRole for the Ribbon Caption, though it should be ignored when on vista and glass is shown, so this sounds like a bug to me. You should submit this issue to Developer Support.
-Matt
I've installed the hotfix, however, the issue remains.
I've narrowed the problem down to the appstyling. If I don't load my ISL file, everything renders fine (Vista style).
However, I need the ISL to be loaded. What ISL properties could cause this strange rendering behaviour?
Make sure you log into that link with a member id that has your cd-keys registered.http://devcenter.infragistics.com/Protected/ProductRegistration.aspx
The downloads are dynamic dependant on the products that you have registered.https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Products
Click on the NetAdvantage tab and then the NetAdvantage product key to see a display of files assocated with that product.Hotfixes will be at the bottom of that registered product page.
Contact support if you have any difficulty with registration or retrival.
http://ko.infragistics.com/support/ask-for-help.aspx#AskforHelp
Hope that helps.
