Hi, I had this error when I changing my Pie chart 3d to 2d. I looked at the designer.cs but cannot find the emSize Property
Value of '-0.1999998' is not valid for 'emSize'. 'emSize' should be greater than 0 and less than or equal to System.Single.MaxValue. Parameter name: emSize
Please let me know how to correc that error
Bobbby,
We continue to update releases for a year past their initial release date. So 2007.3 is still supported, and the latest Hotfix for 2007.3 should contain the fix for the problem you ran into.
Hope this helps,
-Tony
Hi Tony,
we only purchased Net Advantage for Windows Forms until Release 2007.3, in this Release the error seems not to be fixed.
How can we get a hotfix which was published in a later release?
Thanks!
bobbby,
I don't know which hotfix this was in, but you can always download the latest hotfix from the "My Downloads" page of www.infragistics.com
I have the same error.
Please, can you tell me where I get the hotfix.
You're not going blind, or crazy. This was a bug in chart that was recently fixed in a hotfix. You can contact our support team (http://ko.infragistics.com/gethelp ) to get the bits.
