1105
Setting the Default Height of a ToolBar
 we have following scenario. Each MDI child has it own toolbuttons which are set to a main Toolbar docked to the parent form. when a MDI Child is closed or another MDI child is selected then the toolbar items are deleted and new ones are dynamically added. This works fine.
The problem I have is when the last toolbutton is deleted the toolbar shrinks its height to a default height and is resized when the first toolbutton is added. This is makes the UI "flicker". How can I set the toolbar default height?
Thanx
Stefan
  • 44743
    This seems like a bug. When a new merge operation occurs, the updating of the UI should be temporarily suspended, so you shouldn't see a flicker. I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp.
    As a workaround, you could add a ControlContainerTool as the first tool in the toolbar. Add a .NET Label control to your Form and set that as the contained control of the tool. Clear the text from the Label and set it's font size to a large value, like 20. That will impose a minimum height on the toolbar.
