302
AutoStatusText from UltraStatusBar not Showing
Hi
We are developing a MDI-application.
The MDI-parent has a toolbar.
The MDI-childs have a toolbar and a statusbar with a AutoStatusText-panel.
When you hover a button, you should see the tooltiptext of that button on the statusbar.
This worked well, until we switched to the Office 2007-look (with Ribbons).
When you now start a MDI-child (with statusbar) from the MDI-parent, the Text or ToolTipText from
the button that launched the MDI-child, is now being displayed - all the time - in the AutoStatusText-panel.
I've made a testproject to reproduce the problem.
When a remove the toolbar from the MDI-child, the problem is solved.
When a switch off the Ribbon of the MDI-parent, the problem is also solved.
We are developing our project in v7.3, but i made the testproject
in v8.2 and the problem still exists.
I've attached the testproject in a ZIP-file. (Form1 is MDI-parent, Form2 is a MDI-child)
Anyone that could help?
Thanks in advance.
Kevin
UltraStatusBarTest.zip
