90
Tabbed MDI child forms display corrupt
We're using the UltraTabbedMdiManager and the UltraToolManager on our main MDI form. By default our program show the MDI children in the tabbed mode, with UltraTabbedMdiManager set enabled to 'True'. The user's can turn off the tabbed mode and view the forms normally- we do this by setting the UltraTabbedMdiManager enabled to 'False'. This works fine, except for one problem- the MDI child forms appear corrupt when you try to move them after setting UltraTabbedMdiManager enabled to 'false'.
This appears to happen with both 7.3 and 8.2 of the netadvantage releases.
We are using windows vista 64-bit, with aero glass enabled. If we turn off aero glass the problem does not happen.
