320
TreeView.SetDataBinding(object dataSource,string dataMember) and DispalyText
hi,
when setting tree to self reference table like so:
treeView.InitializeDataNode += new InitializeDataNodeEventHandler(treeView_InitializeDataNode);DataRelation r = new DataRelation("name" + group.Key, myData.Tables["Hierarchy" + group.Key].Columns[0], myData.Tables["Hierarchy" + group.Key].Columns[1]);
myData.Relations.Add(r);
treeView.SetDataBinding(myData, "Hierarchy" + group.Key);
and running a small sub to determine which nodes are to be displayed like so:
private void treeView_InitializeDataNode( object sender, Infragistics.Win.UltraWinTree.InitializeDataNodeEventArgs e)
if ((e.Node.Level == 0) && (e.Node.Cells["parentkey"].Value.ToString() != string.Empty))
e.Node.Visible = false;
else
e.Node.Text = e.Node.Cells["childCat"].Value.ToString();
the statement "e.Node.Text = e.Node.Cells["childCat"].Value.ToString();" is executed, but the text attribute of node stays.
any ideas? suggestions? on how to control the Node.Text??
tnx in advance for help.
J.
