85
VisiblePosition of UltraWinGrid Columns Not Updating
I'm working on an application where we need to "remember" the order of the columns in an UltraWinGrid.  As the application is closing, I cycle through all of the columns in the grid and grab the visible position and then save all of the values to the database.  When the application is re-started, I get all of the visible positions from the database and loop through the columns of the grid to set the visible position of each column.
The problem that I'm having is that the VisiblePosition property does not appear to be updating.  I've debugged the closing event of the application and checked the VisiblePosition of the columns, but they are the same as when the application started, ignoring any changes I had made.  Is this the best approach to follow?  If so, why would the property not be getting updated?  I've tried referencing the ColumnsCollection of the grid through Grid.DisplayLayout.Bands[0].Columns and Grid.Rows.Band.Columns and they function the same.
Thanks,  Ryan.
