60
Ultragrid 3-row-Header
I am new to ultrawingrid and i have a requirement of doing the same thing as manni2 wants.  I need the following layout.
| - - group 1 header - - | - -                                    group 2  header                                                    - - |
                                | - -                 header 2.1                 - - | - -                   header 2 .2                  - - |
                                | - -  header 2.1.1 - - | - - header 2.1.2 - - | - - header 2.2.1    - - | - -  header 2.2.2 - - |
|      col 1                  |          col 2            |         col 3           |        col 4                 |       col 5              |
 sample code, external link will be highly appreciated.
Thanks.
  • 469350
    Verified Answer
    You would need to use RowLayouts to acheive this. What you would do is add some columns and set LabelPosition to LabelOnly so that you get column headers that have no cells. You should do this at design-time in the grid designer, so you can just click and drag the layout your want.
