400
Select a node only if either Ctrl or Shift key is pressed
      I have a multicolumn WinTree with the following properties,
ultraTree1.ViewStyle = ViewStyel.Grid
ultraTree1.Override.SelectionType = SelectType.Extended;
ultraTree1.FullRowSelect = false;
 with these settings when a node is clicked it is getting activated and also Selected.  However my requirement is to select the node only when either Ctrl or Shift key is pressed.  Please suggest how to attain this functionality.
Thanks for any help,
spm
