675
Error on UltraGrid when using UltraGridExcelExporter
Using NetAdvantage 2007 vol 3 with HotFix 1053 in a Windows application.
 This is my first attempt at using the UltraGridExcelExporter, based on the sample code given in the online help.
 I added the component to my window and added a context menu item.  The code called by the menu item gets a file name from the user and then the following:
this.ultraGridExcelExporter1.Export(this.dgQueryResult, strFileName);  // dgQueryResult is the UltraGrid, strFileName is a string containing the file name.
When I run this code, I get the following exception:
System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Win.UltraWinGrid.UltraGrid.FireInitializeRow(InitializeRowEventArgs e)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.get_RowScrollRegions()
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.DirtyGridElement(Boolean primaryMetricsDirty, Boolean fInvalidate, Boolean dirtyColMetrics)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.ClearViewStyle(Boolean groupByAffected)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.InitGrid(UltraGridBase grid)
   at Infragistics.Win.UltraWinGrid.UltraGrid.Export(IUltraGridExporter exporter)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, Worksheet worksheet, Int32 startRow, Int32 startColumn)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, String fileName)
This implies a problem with the InitializeRow event on the UltraGrid.  I do have code there so I was suspicious of that code, but I put a breakpoint there and that code does not get executed either before or after the exception hits .
I'm looking for suggestions on how to debug this issue.  I don't have the UltraGrid source code, so I can't tell what object is not instantiated.
