665
key not found - Parameter name: key
When I run the following code (VB.Net) I get the error message:  key not found Parameter name: key  when I try to attach the [Grid] to a [Tab]
 Is this a "key" property with the [Grid] or with the [Tab] that it resides on?
I'm dynamically adding the [Tab] and the [Grid] at runtime.
If I insert a [Grid] on a [Tab] at design and run similar code to load my data, I do not get this error message.
What have I missed?
Dim OptiSaveViewGroup As New clsGroups()
Dim osvgGroupDataSet As DataSet = OptiSaveViewGroup.GetOptiSaveViewData2(CInt(txtRunNumber.Text))
Dim Grid1 As UltraWinGrid.UltraGrid
Grid1 = New UltraWinGrid.UltraGrid
With Grid1
.DataSource = osvgGroupDataSet
.DisplayLayout.Appearance.BackColor = Color.White
.DisplayLayout.Appearance.BorderColor = Color.DarkGray
.DisplayLayout.Appearance.Key = "Tab2"
.DisplayLayout.Bands(0).HeaderVisible = True
.DisplayLayout.Bands(0).Header.Caption = "OptiSave Report"
.DisplayLayout.Bands(0).AutoPreviewEnabled = True
.DisplayLayout.AutoFitStyle = UltraWinGrid.AutoFitStyle.ResizeAllColumns
.DisplayLayout.ScrollBounds = UltraWinGrid.ScrollBounds.ScrollToFill
.DisplayLayout.ScrollStyle = UltraWinGrid.ScrollStyle.Immediate
.DisplayLayout.Override.AllowRowFiltering = DefaultableBoolean.True
.Dock = DockStyle.Fill
End With
UltraTabControl1.Tabs(ActiveTabName).TabPage.Controls.Add(Grid1)
Grid1.Refresh()
Thanks ahead of time.
