436
Turn Off Column Sort Indicator
I am looking for a way to turn off the display of the Sort Indicator on a sorted column while retaining the ability for the user to sort the column.
I have searched the forum and found a similar question - the suggested fix was to use a CreationFilter on the grid to cancel the creation of the SortIndicatorUIElement.
This does stop the indicator being displayed - however my problem is that the space is still made for the indicator anyway. How do I prevent this?
This results in wrapping of the header text unless I resize the column to fit the updated column header.
I have very strict (and unique!) requirements to save as much space as possible to resizing the column is not an option. I need to hide the indicator AND stop the grid reserving space for it also.
I have tried numerous workarounds involving resetting the columns SortIndicator property to None. This does the trick when sorting Ascending however when sorting Descending it reverts the sort to Ascending :-(
 Any suggestions are most welcome.
Thanks!
