515
Row Selector Click / Own Column
Hi Guys
I am having some troubles isolating the click event of the row selectors, mainly because I use RowSelectorNumberStyle.RowIndex, and the row index is a text element...
I have used a DrawFilter to remove the selector arrows.
I have already trapped the column header click with no problems using the following code on mouse down:
Dim ThisUIElement As UIElement
Dim ThisHeader As ColumnHeader
ThisUIElement = Grid.DisplayLayout.UIElement.ElementFromPoint(New Point(e.X, e.Y))
If Not ThisUIElement Is Nothing Then
    ThisHeader = ThisUIElement.GetContext(GetType(ColumnHeader))
    If Not ThisHeader Is Nothing Then
        *Code*
    End If
End If
This seems to pay no attention to whether I click the column header caption or not... Unfortunately, with the row selectors, clicking on the row index numbers makes the current UIElement a TextElement rather than RowSelectorUIElement
How can I isolate a click event on a row selector whether it is on the row index or not?
Also, is there any way to have the row selectors occupy their own column space, rather than overlap the first column in the grid?
Thanks in advance!
