160
Non-overlapping LineChart lines
I am using a UltraChart of type LineChart and some of the lines overlap from start to end. Thus, the colors get combined and it is not very clear which of the lines is for a specific plot. Is it possible to make the lines non-overlapping, without adding/substracting a constant from the values?
Thank you.
  • 26458
    Can you post an image of what you're describing? I'm having a hard time picturing what you're trying to do. Lines are based on the data you supply, so the only overlapping i can think of would be because some of the data values are the same.
