Hi!
Is it possible to set Grid orientation (Portrain/Landscape) before Printing or Exporting to PDF? We have all our grids to be printed Landscape and don't want to bother user to change orientation manually every time.
Thank you. It works.
Does this post answer your use case?
http://news.infragistics.com/forums/t/11906.aspx
If you are using the UltraGridPrintDocument, this should set the orientation:
private void ultraGridPrintDocument1_QueryPageSettings(object sender, System.Drawing.Printing.QueryPageSettingsEventArgs e) { e.PageSettings.Landscape = true; }
Let me know if this help,
Jason
