I have set property of Grid CellClickAction = RowSelect;
I am able to unselect multiple row by writing small code on Mouseclick event
foreach (UltraGridRow row in ugAgtState.Selected.Rows){row.Selected = false; } //after I will select single row where mouse is located
Is there any property saying MultiSelect = false? if yes, Please let me know where it is in Grid Properties as I am unable to found it.
Actually, if you only want to deal with one "selected" row, you are probably better off setting:
grid.DisplayLayout.Override.SelectTypeRow = None
Then you just work with the grid.ActiveRow instead of the selected row. If you want to highlight the active row, use the ActiveRowAppearance (also on the Override object).
No need to write custom code. Set the MaxSelctedRows property value to 1.
This property is under DisplayLayout --> Override --> MaxSelectedRows
