1005
Tooltip position problems
I have a form that contains several panels, each with a chart on it (actually each chart is on it's own form and an instance of that form is added to each panel).  I have the following two problems with tooltips, which may a may not be related:
1. The tooltip appears about 2 inches (!) below the mouse position, this deosn't seem right and looks ridiculous.
2. When I set the tooltip overflow option to ChartArea (or ClientArea) the tooltips always appear on the first chart, even when I hover over a data point on one of the other charts!
Any ideas on what's causing these problems and how I can fix them?
I'm using version 8.3 with Visual Studio 2008.
Thanks.
Brian
