2306
Question about Enable Property of a UltraTab
 Hello!
Suppose you have 2 tabs on a ultratab control, for example: Tab1,Tab.
My requirements are that a user can switch between tabs but cannot edit data within the tabs.
Now, i have tried to set the enable property to false,
 ultraTabControl1.Tabs["Tab1"].Enabled = false;
 ultraTabControl1.Tabs["Tab2"].Enabled = false;
and it works partially, i mean the user cannot edit  the data but the problem is that switching between tabs does not work.
how can i achieve that behaviour?
thank you
