Showing and hiding toolbars when the Alt key is pressed is not supported. You can submit a feature request for this: http://devcenter.infragistics.com/Protected/RequestFeature.aspx. As far as the underlines for hotkeys, this issue has already been submitted. You can submit the issue and reference issue BR26218 to be notified when a fix or workaround is found.
