Hi Mike,
It works and thanks for the reply.
Ceaser
I assume you mean the text is removed and the button is collapsed to only have an icon. If so, you can set the tool's InstanceProps.MinimumSizeOnRibbon to Normal. That will prevent the tool from collapsing. If you mean part of the text is being cut off, this may be a bug and I would recommend submitting it to the support group: http://ko.infragistics.com/gethelp.
