I implemented UltraGrid_MouseUp event handler, wanted to dynamically pop up contextmenu when the mouse being clicked on the grid.But it did not work, it got a system overflow. Can you point out why, and what is the right way to do?
private void ultraGrid1_MouseUp( object sender, MouseEventArgs e ){......... contextMenuStrip1.Items.Add( "Assigned", null, new System.EventHandler( this.Assigned_OnClick ) ); // Add a menu item for the Unchecked state. contextMenuStrip1.Items.Add( "Unassigned", null, new System.EventHandler( this.Unasssigned_OnClick ) );
contextMenuStrip1.Location = ultraGrid1.PointToScreen(e.Location);
contextMenuStrip1.Show( contextMenuStrip1, e.X, e.Y );..........}
if I don't position it, the menu goes to left-top corner of the screen.
Also how the handler Assigned_OnClick() get to use the EventArgs "e" in its implementation?
protected void Assigned_OnClick( System.Object sender, System.EventArgs e ){ MessageBox.Show( "Assigned_OnClick: " + e.ToString() );}
When I removed the setting of the Location, it worked.
// contextMenuStrip1.Location = ultraGrid1.PointToScreen(e.Location);
It will be appreciated If anyone can share how to utilize "System.EventArgs e" in the handler.
contextMenuStrip1.Show( ultraGrid1, new Point( e.X, e.Y ) );
I'm confused. Have you solved this problem? I don't see anything here that could cause an overflow exception. What does the call stack look like when the exception occurs?
