165
Converting UIElement to UltraListViewItem
I have an UltraListView that is populated with several items. What I am trying to do is have an action happen to the UltraListViewItem when a mouse enters and leaves the item, using the MouseEnterElement and MouseLeaveElement events. Unfortunately I don't know how to get the UltraViewListItem from the UIElementEventArgs that is passed into those methods. This is what I have tried but does not work:
private void Browser_MouseEnterElement( object sender, Infragistics.Win.UIElementEventArgs e )
            UltraListViewItem itemEnter = e.Element as UltraListViewItem;
            if( itemEnter != null )
                //do stuff with item
        private void Browser_MouseLeaveElement( object sender, Infragistics.Win.UIElementEventArgs e )
            UltraListViewItem itemLeave = e.Element as UltraListViewItem;
            if( itemLeave != null )
  • 69832
    Verified Answer
    The UltraListViewItemUIElement class encapsulates the item's physical representation on the screen; it derives (as all such Infragistics classes do) from UIElement. When handling MouseEnterElement/MouseLeaveElement, cast e.Element to the expected type, then check for a non null return. Note that in this case, the element class exposes a property that references the underlying object, but for UIElement classes that don't, you can oftentimes use the UIElement.GetContext method to get that reference.
    Example:
    private void Browser_MouseEnterElement(object sender, UIElementEventArgs e)
        UltraListViewItemUIElement itemElement = e.Element as UltraListViewItemUIElement;
        UltraListViewItem item = itemElement != null ? itemElement.Item : null;
        if ( item != null )
            System.Diagnostics.Debug.WriteLine( item.Text );
