PropertyCategories.All
When i sort any column on the grid and save the layout, the column ordering goes bizzare. If i do not sort the column everythign works fine.
Any inputs?
Hello rajkumarthic,
Please let me know which version of NetAdvantage you are using. I tried this with NetAdvantage 2011 Volume 1 and was unable to reproduce the issue. It would also be helpful if you could provide a sample project which reproduces the issue.
